I've just installed a fresh copy of Ubuntu 13.04, and tried installing the NVIDIA drivers for my GeForce GT540M. This just completely broke my Unity. After rebooting I can login, but it just shows my desktop without the Launcher and top Panel. Also the resolution was 640x480 (instead of 1920x1080) and I was not able to change it via command line (no modes found, etc.).
I've tried a lot of solutions already:
  • Using the mainline kernel instead of the default one
  • Using CCSM to re-enable Unity plugin, problem here was that it didn't show Unity
  • Removing Compiz config files
  • Starting Unity in 2D mode, but I wasn't able to do this because I could not find the option on the login screen
  • Delete .Xauthority in the home folder
  • Remove and install Unity again
The problem is none of these possible solutions work. I've seen others with the same problem and these solutions worked for some of them, but it doesn't for me.
EDIT: In the meantime I’ve found an even better solution than using primus. Since one of the later driver versions, Optimus is support (although just basic) by the package nvidia-prime which is part of the proprietary drivers. Install the drivers like so:
sudo apt-get install nvidia-331 nvidia-settings-331 nvidia-prime
Afterwards restart your computer. Now the driver will only be enabled when needed, just like it does on Windows.
karel
  • 122,292
  • 133
  • 301
  • 332
As I know GT540M is optimus graphical card. Next time install Bumblebee.
sudo add-apt-repository ppa:bumblebee/stable
sudo apt-get update
sudo apt-get install bumblebee bumblebee-nvidia
to run some app with GT540M:
optirun executable_app
To solve you problem: remove drivers that you installed.
As stated earlier install bumblebee, but also Install primus and use primusrun instead of optirun, performance is much better. It's recommended by steam and bumblebee developers
Ubuntu wiki: https://wiki.ubuntu.com/Bumblebee#Installation
Steam support: https://support.steampowered.com/kb_article.php?ref=6316-GJKC-7437 (highly recommends not using primusrun steam/optirun steam as it negates any power saving but provides a command that can be added to steam games through menus in your library, I suggest using primusrun %COMMAND% as the command listed wont work entered lowercase)
Awesome guide: http://cjenkins.wordpress.com/2013/01/01/steam-for-linux-on-optimus-enabled-computer-running-ubuntu-12-04-64bits/
