I'd like to install Ultrastar Deluxe in Ubuntu 13.04. However, the PPA only contains packages for Ubuntu 12.10, 12.04, 10.10 and 10.04.
Is there any way I can install Ultrastar Deluxe in Ubuntu 13.04?
I have successfully installed UltraStart on my notebook MSI U100. Download the packages from https://launchpad.net/~tobydox/+archive/ultrastardx/+packages
I used first: ultrastar-deluxe-data_1.1.0-svn-20120608-1_all.deb
then: ultrastar-deluxe_1.1.0-svn-20120608-1_i386.deb
And not had problems. I hope it works for you too!
Greetings!    Javier.
Yes, you can. After you have installed the ppa sources, go and modify them for which distribution you want (quantal for Ubuntu 12.10 version for example): press Super (windows button), write Software & Updates, open it, go to Other sources, select which ppa want to modify and press Modify.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Currently the easiest way to install Ultrastar Deluxe for all supported Ubuntu versions, including 15.10 is
sudo add-apt-repository ppa:tobydox/ultrastardx
sudo apt-get update
sudo apt-get install ultrastar-deluxe
after staring it by running
ultrastardx
you can find the songs folder under your home directory
~/.ultrastardx/songs/
TheFisch
  • 103
