This was an issue with moving to 12.10 it appears to have resurfaced now with 13.04 i.e. post upgrade to 13.04 you still get the MOTD to upgrade.
I've tried the previous list of fixes for the same issue re move to 12.10 https://askubuntu.com/questions/253844/upgrade-12-04-2-lts-to-12-10-do-release-upgrade-fails-no-new-release-found but they don't seem to work, i.e. there is no /var/lib/update-notifier/release-upgrade-available to remove.
I just "touch" the file /var/lib/ubuntu-release-upgrader/release-upgrade-available
But don't know why this file will not refresh automatically.
Henry
  • 31
In a similar situation I found that there is another file /run/motd.dynamic apart from /run/motd and the old message persisted /run/motd. Both are called by pam_motd which states that /run/motd is static.
# This includes a dynamically generated part from /run/motd.dynamic
# and a static (admin-editable) part from /etc/motd.
The solution was just to empty the static file:
echo -n "" | sudo tee /run/motd
jnas
  • 468
