I installed Ubuntu Desktop 13.10 64-bit in VMware.
I am trying to compile PHP 5.4.14 on the machine. Here's the bit where make stops due to an error:
/usr/bin/ld: ext/mysqlnd/.libs/mysqlnd_net.o: undefined reference to symbol 'uncompress'
/usr/bin/ld: note: 'uncompress' is defined in DSO /lib/x86_64-linux-gnu/libz.so.1 so try adding it to the linker command line
/lib/x86_64-linux-gnu/libz.so.1: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make: *** [sapi/cli/php] Error 1
I have the same version of php compiled and built on a 12.10 32-bit VM and it seems to be working properly.
I have checked that I have zlib1g zlib1g-dev and zlibc installed. What could be the problem?
F21
  • 4,349
--with-libdir=lib64 should do the trick. I think you forgot to do a make clean after adding the --with-libdir configuring and prior to make compile . I've just compiled php version 5.5.2 using phpfarm and initially encountered the same issue described by you when using --with-mysqli=mysqlnd. Adding --with-libdir=lib64 AND make clean fixed the issue.
guntbert
  • 13,475
KJE
