TortoiseHG previously worked on 12.10, but after today's reinstall, it simply doesn't show up, not even with the thg command.
Asked
Active
Viewed 2,903 times
11
Basharat Sialvi
- 24,156
rebelliard
- 417
10
I managed to install it rather easily by using the tortoisehg ppa:
sudo add-apt-repository -y ppa:tortoisehg-ppa/releases
sudo apt-get update
sudo apt-get install mercurial tortoisehg
Note: @piwi's method works too.
rebelliard
- 417
This is not a solution but rather a workaround. The version of TortoiseHG from the repository works fine.
I first installed the latest version of mercurial (otherwise thg will complain about a version mismatch for hg); I installed it in ~/opt:
hg clone --branch stable http://selenic.com/hg ~/thg/mercurial
cd ~/thg/mercurial
python setup.py install --prefix=$HOME/opt
export PATH="$HOME/opt/bin:$PATH"
export PYTHONPATH="$HOME/opt/lib/python2.7/site-packages:$PYTHONPATH"
I use bash, so I needed to remove the hash entry for mercurial:
hash -d hg
Then I made a copy of the thg repository and ran it from the repository I wanted to work from:
hg clone --branch stable http://bitbucket.org/tortoisehg/thg ~/thg/tortoisehg
cd ~/devel/myrepo
~/thg/tortoisehg/thg
piwi
- 111
