And if so, how?
The only way I found was by a new install, and I'd like to know if there is an alternative like in previous versions.
karel
  • 122,292
  • 133
  • 301
  • 332
There are two ways to upgrade to 13.04 without loosing your data:
  • You can upgrade your current install
You will get a promt asking you to upgrade in a couple of days (2 weeks after release I think), or you can upgrade now by typing sudo do-release-upgrade in a terminal
  • You can install over your current installation without formating the drive
    • Download ubuntu 13.04 and create a startup USB disk or burn it to a CD/DVD.
    • Install as you normally would.
    • When asked select "Upgrade Ubuntu 12.10 to 13.04"
Your data should not be overwritten, but it is good practice to back up your data anyway.
If you have a more complicated set up (such as separate /home partition) you can select "something else" and assing your partitions as you did before. But make sure not to put the checkmark to format you "/home" partition
Uli
  • 5,196
An upgrade should preserve your data.
However you should make a backup of any important data.
Making a backup should not be considered optional, a best practice or recommended, I would say it is an absolute. If you need to buy an external drive, a bunch of USB sticks or whatever, this is something you just really really should do.
Regardless of version control systems or whatever, I always backup files before upgrades, running sed scripts, reorganizing files, etc.
Any task that might, conceivably mess up the files, will eventually do that. If it only has a 0.1% chance per day then once every 3 years it will (on average) happen.
