I have a laptop, and I want to install Indonesian language pack. Unfortunately, there is no Internet connection. Can I install language packs offline (assuming I can download files in another computer)?
Log:
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-gnome-id-base/language-pack-gnome-id-base_12.04+20120417_all.deb Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-id-base/language-pack-id-base_12.04+20120417_all.deb Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-id/language-pack-id_12.04+20120417_all.deb Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-gnome-id/language-pack-gnome-id_12.04+20120417_all.deb Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/f/firefox/firefox-locale-id_11.0+build1-0ubuntu4_all.deb Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libr/libreoffice/libreoffice-l10n-id_3.5.2-2ubuntu1_all.deb Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openoffice.org-hyphenation/openoffice.org-hyphenation_0.6_all.deb Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/poppler-data/poppler-data_0.4.5-2_all.deb Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/t/thunderbird/thunderbird-locale-id_11.0.1+build1-0ubuntu2_all.deb Could not resolve 'archive.ubuntu.com'
edit: I've trying myself to run terminal and use gksudo file-roller to open Archive manager with elevated rights, and extract all of contents of package manually, but didn't works.
Alexandre
  • 1,968
Aryo Adhi
  • 1,397
  • 15
  • 41
yes you can do it.open your terminal and paste these lines one by one
mkdir lan
cd lan
wget http://shadow.ind.ntou.edu.tw/ubuntu//pool/main/l/language-pack-id-base/language-pack-id-base_12.04+20120417_all.deb
wget http://sg.archive.ubuntu.com/ubuntu/pool/main/l/language-pack-id/language-pack-id_12.04+20120417_all.deb
sudo dpkg -i *.deb
for more information: http://packages.ubuntu.com/precise/translations/
Raja G
  • 105,327
  • 107
  • 262
  • 331
Download the .deb packages and install them with sudo dpkg -i *.deb.
To download them:
wget http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-gnome-id-base/language-pack-gnome-id-base_12.04+20120417_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-id-base/language-pack-id-base_12.04+20120417_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-id/language-pack-id_12.04+20120417_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-gnome-id/language-pack-gnome-id_12.04+20120417_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/f/firefox/firefox-locale-id_11.0+build1-0ubuntu4_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/libr/libreoffice/libreoffice-l10n-id_3.5.2-2ubuntu1_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/o/openoffice.org-hyphenation/openoffice.org-hyphenation_0.6_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/p/poppler-data/poppler-data_0.4.5-2_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/t/thunderbird/thunderbird-locale-id_11.0.1+build1-0ubuntu2_all.deb
caugner
  • 141
You can download those packages, and then use dpkg to install them manually.
How to download the packages
Run the command
wget http://archive.ubuntu.com/ubuntu/pool/main/f/firefox/firefox-locale-id_11.0+build1-0ubuntu4_all.deb http://archive.ubuntu.com/ubuntu/pool/main/libr/libreoffice/libreoffice-l10n-id_3.5.2-2ubuntu1_all.deb http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-gnome-id-base/language-pack-gnome-id-base_12.04+20120417_all.deb http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-gnome-id/language-pack-gnome-id_12.04+20120417_all.deb http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-id-base/language-pack-id-base_12.04+20120417_all.deb http://archive.ubuntu.com/ubuntu/pool/main/l/language-pack-id/language-pack-id_12.04+20120417_all.deb http://archive.ubuntu.com/ubuntu/pool/main/o/openoffice.org-hyphenation/openoffice.org-hyphenation_0.6_all.deb http://archive.ubuntu.com/ubuntu/pool/main/p/poppler-data/poppler-data_0.4.5-2_all.deb http://archive.ubuntu.com/ubuntu/pool/main/t/thunderbird/thunderbird-locale-id_11.0.1+build1-0ubuntu2_all.deb
(it is a long command line; once you run it, it will download all packages that you referenced above).
How to install the packages
Run the command
sudo dpkg -i *deb
(assuming that no other .deb files exist in the same direcory).
That's it!
user4124
  • 9,241
