Recently I found /run/lock and /run/shm folders to be missing.
I tried to recover some files with a mounted disk, I now know that this may caused the harm. So unaware what to do, I created these directories by myself.
Now I looked up the command df -h and saw this output:
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda6             913G   69G  798G   8% /
udev                  5,9G  4,0K  5,9G   1% /dev
tmpfs                 2,4G  872K  2,4G   1% /run
none                  5,0M     0  5,0M   0% /run/lock
none                  5,9G  2,1M  5,9G   1% /run/shm
/dev/sda1             915M  358M  509M  42% /boot
I didn't know there were such file systems, how can I mount them in again? Is this something harmful?
I also saw that I have high I/O with my Journal jbd2/sda6-8 always around 40%, has this something to do with this?
dan-lee
  • 233
I think df is getting thrown by the lack of specified device. If you look with mount, you'll see that the filesystem is definitely tmpfs.
$ df -h | grep run
tmpfs                          4.8G  1.4M  4.8G   1% /run
none                           5.0M     0  5.0M   0% /run/lock
none                            12G  4.9M   12G   1% /run/shm
none                           100M  8.0K  100M   1% /run/user
$ mount | grep run
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
none on /run/user type tmpfs (rw,noexec,nosuid,nodev,size=104857600,mode=0755)
rpc_pipefs on /run/rpc_pipefs type rpc_pipefs (rw)
I would guess that because tmpfs is a ram-disk that you don't actually need to specify a block level object to "mount".
I would certainly welcome people correct me if that assumption is incorrect but for your case there is nothing to worry about. They're not missing, they're just mounted funny... And that just happens to be the way all my Ubuntu computers here are also set up. Panic not.
Oli
  • 299,380
