$ sudo aptitude safe-upgrade
The following packages will be upgraded:
linux-image-generic-pae
1 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/2,578 B of archives. After unpacking 1,024 B will be used.
Do you want to continue? [Y/n/?] Y
dpkg: dependency problems prevent configuration of linux-image-generic-pae:
linux-image-generic-pae depends on linux-image-3.2.0-36-generic-pae; however:
Package linux-image-3.2.0-36-generic-pae is not installed.
dpkg: error processing linux-image-generic-pae (--configure):
dependency problems - leaving unconfigured
No apport report written because MaxReports is reached already
A package failed to install. Trying to recover:
Does anyone know how to fix this? I've tried sudo apt-get clean and sudo apt-get autoremove along with sudo apt-get install -f. None of these have fixed my issue.
