I've installed Ubuntu, but when it is loading it gives following error:
mount:can't read proc/mounts. Can't fount such file or directory
However, OS continues loading but when I try to enter system using my login/password, which I entered during installation, it fails to login.
Does someone know what is problem here? I've tried reinstall ubuntu several times, but problem still occurs.
Medium from I installed: Windows 7. Installed Ubuntu with wubi, where I chose separate disk G(NTFS file format), set installation size: 18GB, chose Ubuntu in dropdownlist, language English(GB) and set username and password.
guntbert
  • 13,475
Nurlan
  • 159
This is a caused by running an out of date wubi.exe from 12.04 or 12.04.1 (refer to bug Wubi 12.04 installs development release). Because the Wubi.exe is out of date it tries to download the development release wubi disk image. These are no longer created, but there is still a broken one from the 13.04 development release sitting out there, so it gets downloaded.
You need to get the latest Wubi for 12.04.2 from here: http://releases.ubuntu.com/12.04/wubi.exe
Or the 12.10 Wubi from here: http://releases.ubuntu.com/12.10/wubi.exe
There is also a 13.04 Wubi here: http://releases.ubuntu.com/13.04/wubi.exe
Any of these will work.
bcbc
  • 6,036
Go to Wubi installation folder
C:\ubuntu\install
open file
wubildr-disk.cfg
The content is:
loopback loop0 /ubuntu/disks/root.disk
set root=(loop0)
search --set=diskroot -f -n /ubuntu/disks/root.disk
probe --set=diskuuid -u $diskroot
linux /vmlinuz root=UUID=$diskuuid loop=/ubuntu/disks/root.disk preseed/file=/ubuntu/install/preseed.cfg wubi-diskimage ro quiet splash
initrd /initrd.img
boot
Change it to this:
set root=(loop0)
linux /vmlinuz root=UUID=$diskuuid loop=/ubuntu/disks/root.disk preseed/file=/ubuntu/install/preseed.cfg wubi-diskimage ro quiet splash **single**
initrd /initrd.img
boot
That single word should be in same line and that is the only change
Then reboot your computer, and choose Ubuntu and it will boot into single user root mode
Create and user with command
adduser steve
and then add the user in sudo group
usermod -G sudo steve
Then type reboot
Go to windows and restore that wubildr-disk.cfg file to original version without the word single
reboot into Ubuntu and you will have steve user available to login from the login prompt.
Videonauth
  • 33,815
