I tried to install qt-sdk under ubuntu 12.10 how can I fix this issue?
install log:
apt-get install qt-sdk
Reading package lists... Done
Building dependency tree
 qt-sdk : Depends: qt4-designer but it is not going to be installed
          Depends: qt4-dev-tools but it is not going to be installed
mbnoimi
  • 204
First do
sudo apt-get install qtcreator
sudo apt-get install qt4-designer
sudo apt-get install qt4-dev-tools
then
sudo apt-get install qt-sdk
thefourtheye
  • 4,922
  • 26
  • 32
