while trying to install zopectl and zope testcase I am getting this error:
oomsys@oomsysmob-6:~/zopectl$ sudo apt-get install zopectl
Reading package lists... Done
Building dependency tree
E: Unable to locate package zopectl
I put the tar file in my home directory. But I don't know why I am getting this error. Can anyone tell me the reason?
Jorge Castro
  • 73,717
With many applications, there are multiple ways to download/install them. One way is through apt-get and another is by downloading and untaring the .tar file. Note, that apt-get has nothing to do with the .tar file.
Typically, that error indicates the package you are trying to install cannot be found in any of your defined repositories. Have you done a sudo apt-get update? Run that command and then try again.
If you cannot get the apt-get install to work, you should be able to install this application by untar-ing the .tar file (which you say you have already downloaded). In terminal, change to your home directory (cd ~) and try this:
tar -xvf nameOfTarFile.tar
Note that if the file you downloaded is a tar.gz file, you'll need to set one more flag to get that to work:
tar -zxvf nameOfTarFile.tar
Aaron
  • 6,764
