I am planning to purchase a Targus 3.0 docking station, does anybody have experience with it on Ubuntu.
Will the display work?
http://www.targus.com/uk/CategorySearch.asp?SearchedTerms=usb+docking+station&Action.x=0&Action.y=0
LiveWireBT
  • 29,597
Calin
  • 705
7 Answers7
I can confirm that the displaylink driver works. I just bought the "Targus ACP71USZ USB 3 Docking Station with HD Video and Power Adapter" and I have installed the drivers (version 1.0.138) as instructed at
http://support.displaylink.com/knowledgebase/articles/615714#ubuntu
Things so far have worked out smoothly in my Ubuntu 15.04 system. Configuration through the gnome system settings has been easy. I have encountered only one minor glitch. The speakers do not work through the docking station. Surprisingly, in the sound settings the Targus microphone input is detected but the output is not. Not a deal breaker, though.
Gamx
  • 105
I have the Targus USB 3.0 Dual Video Docking Station, recently purchased. I bought it with a Dell XPS 13 ("Sputnik"), and it works for USB, Ethernet with this Dell Ultrabook.
The sound out does not work (I haven't tested microphone). The video out does not work with the supplied connectors for either the HDMI or DVI ports. I believe that there are some 'code enhancement opportunities' for USB3 video and Ubuntu.
The Dell machine is running 12.04LTS: 3.2.0-29-generic #46+kamal5~DellXPS-Ubuntu SMP Sun Jul 29 18:49:08 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux.
m3topaz
  • 36
EDIT: DisplayLink now provides drivers for ubuntu here. Last time I checked (several months ago tbh), it worked, but was using quite a lot of CPU.
Displaylink drivers for usb 3.0 is not implemented for linux. See http://www.displaylink.org/forum/showthread.php?t=1748
Especially, an official says they have no plan to release it anytime soon : http://www.displaylink.org/forum/showpost.php?p=8935&postcount=23
But if you have time, participating in making the support for usb2.0 displaylink better might make them change their point of view, see post 35 (can't link here, because not enough rep).
autra
  • 275
For me :
  • ethernet connection : ok
  • sound out : ok
  • hub usb : ok
  • display : not working
Here is my xrandr output:
$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 294mm x 165mm
   1920x1080      60.0*+   59.9     40.0
VGA1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
DP1 disconnected (normal left inverted right x axis y axis)
It seems to see the display but not the connection !
user154731
" Below is the latest download from DisplayLink for Ubuntu distributions. This release has been prepared to be compatible with Ubuntu 14.04.x LTS and 16.04 LTS. Other variants and editions may be compatible if they meet minimum O/S requirements, but are not supported by DisplayLink. Please see our support page for information on how to install this driver on Ubuntu."
http://www.displaylink.com/downloads/ubuntu
Justaman
  • 111
the manufacturer should be "DisplayLink" Linux driver are WIP check: http://libdlo.freedesktop.org and discussion on http://www.displaylink.org/forum/forumdisplay.php?f=29
TiloBunt
  • 2,315
It looks like DisplayLink will not develop proper drivers for Linux until enough interest is shown.
sic. "[...]DisplayLink has refused to support linux or the community until sufficient interest is shown, or there's better linux "support for the DL-1x5[...]"
Mitch
  • 4,807
sircac
