There are 4 ways that I can think of for installing/using the radeon driver:
- Use the built-in open-source version of it (isn't too ideal for gaming though)
- Use Ubuntu's built-in driver detection & installation tool: Jockey
- Install the catalyst driver using the 3rd party installer (what you did)
- Install the catalyst driver in the ubuntu repositories:
fglrx
We'll first undo what you did in the 3rd method (very important to do this before anything else), so open a terminal, and run one of these commands (run the first, if it doesn't work, run the second, etc...):
sudo aticonfig --uninstall
sudo sh ./amd-driver-installer-catalyst-13.1-legacy-linux-x86.x86_64.run --uninstall (cd to where that file is located first)
sudo sh /usr/share/ati/amd-uninstall.sh
Next, we'll try to use Jockey to install it:
sudo jockey-gtk
Somewhere in the list, this text should appear:
ATI/AMD proprietary FGLRX graphics driver
Select that, then click Activate, and once it's done, reboot, and test it by running:
glxgears
If it returns No command 'glxgears' or The program 'glxgears' is not installed (or similar), run this:
sudo apt-get install mesa-utils
And then repeat the test. If everything goes fine, there should be a window with gears moving around, and in ~5 seconds, it should report the framerate.
Now if it doesn't work, we'll have to install it by hand:
sudo apt-get purge fglrx
sudo apt-get install fglrx
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.bak
sudo aticonfig --initial
Then reboot. Repeat the test that I listed above, and it should work.
