I am running 12.04 LTS on a ASUS custom build server. I apologize in advance as my skills are a bit rusty in linux as I spend more time working with networking gear these days.
I am running sudo apt-get upgrade after I ran sudo apt-get update and I get the follwoing:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 linux-image-server : Depends: linux-image-3.2.0-39-generic but it is not installed
 linux-server : Depends: linux-headers-server (= 3.2.0.39.47) but 3.2.0.40.48 is installed
E: Unmet dependencies. Try using -f.
So when I run sudo apt-get -f install I get the following:
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
  linux-image-3.2.0-37-generic
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  linux-image-3.2.0-40-generic linux-image-server linux-server
Suggested packages:
  fdutils linux-doc-3.2.0 linux-source-3.2.0 linux-tools
The following NEW packages will be installed:
The following packages will be upgraded:
2 upgraded, 1 newly installed, 0 to remove and 124 not upgraded.
3 not fully installed or removed.
Need to get 0 B/38.6 MB of archives.
After this operation, 150 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 373700 files and directories currently installed.)
Unpacking linux-image-3.2.0-40-generic (from .../linux-image-3.2.0-40-generic_3.2.0-40.64_amd64.deb) ...
Done.
dpkg: error processing /var/cache/apt/archives/linux-image-3.2.0-40-generic_3.2.0-40.64_amd64.deb (--unpack):
failed in write on buffer copy for backend dpkg-deb during ./boot/abi-3.2.0-40-generic': No space left on device
No apport report written because the error message indicates a disk full error
 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.2.0-40-generic /boot/vmlinuz-3.2.0-40-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.2.0-40-generic /boot/vmlinuz-3.2.0-40-generic
E: Sub-process /usr/bin/dpkg returned an error code (1)`
As you can see there is a disk full error message so I tried to purge some of the unused kernels following a process posted on another question I found.
I ran sudo apt-get purge linux-image-x.x.x.x-generic where x.x.x.x is a kernal version I was not using but I get the same error of suggesting to run apt-get -f install I got when I ran sudo apt-get upgrade.
Is there something I am just not remembering to help me clear space up here or another way to purge unneeded kernel images?
An attempt to run sudo dpkg --configure -a results:
Setting up initramfs-tools (0.99ubuntu13.1) ...
update-initramfs: deferring update (trigger activated)
dpkg: dependency problems prevent configuration of linux-image-server:
 linux-image-server depends on linux-image-3.2.0-39-generic; however:
  Package linux-image-3.2.0-39-generic is not installed.
dpkg: error processing linux-image-server (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-server:
 linux-server depends on linux-image-server (= 3.2.0.39.47); however:
  Package linux-image-server is not configured yet.
 linux-server depends on linux-headers-server (= 3.2.0.39.47); however:
  Version of linux-headers-server on system is 3.2.0.40.48.
dpkg: error processing linux-server (--configure):
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.2.0-38-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.2.0-38-generic with 1.
dpkg: error processing initramfs-tools (--configure):
 subprocess installed post-installation script returned error exit status 1
 linux-image-server
 linux-server
 initramfs-tools
Results of df -h. Couldn't remember that command for the life of me to see the space. Get a good laugh at the boot size especially since it is on that 500GB drive with not much being used there. I can't steal from /dev/sdb1 as that is isolated physical drive for share space among all users and can be taken out and moved to any system easily should the need arise.
Filesystem            Size  Used Avail Use% Mounted on
/dev/mapper/NAS-root  455G   11G  421G   3% /
udev                  2.0G  4.0K  2.0G   1% /dev
tmpfs                 791M  768K  790M   1% /run
none                  5.0M     0  5.0M   0% /run/lock
none                  2.0G     0  2.0G   0% /run/shm
/dev/sdb1             1.8T  929G  813G  54% /media/windows
/dev/sda1             228M  228M     0 100% /boot
Can't remember when I built this server but it will be the last time I let it select sizes for partitions automatically. I am guessing my best bet is to follow these instructions for increasing partition size? http://ubuntuforums.org/showthread.php?t=1219270
Any worries with data corruption by stealing from /dev/mapper/NAS-root?
Well I finally cleared space up correctly but I am still getting a dependency issue when trying to run sudo apt-get -f install.
2 upgraded, 0 newly installed, 0 to remove and 124 not upgraded.
2 not fully installed or removed.
Need to get 0 B/4,320 B of archives.
After this operation, 2,048 B of additional disk space will be used.
No apport report written because MaxReports is reached already
 linux-image-server
 linux-server
Not sure how to even begin to fix this issue since there is a newer version of the kernal file there but it is looking for an older version.
If sudo apt-get -f install did not work, then try this:
sudo apt-get clean
or,
sudo apt-get autoclean
For sudo apt-get -f install, try running:
Then run:
Hope this helps!
horIzoN
  • 1,084
