When I try to run an example application it says I am missing a file that is found in OpenGL. I found information online and tried to install OpenGL with the following command:
sudo apt-get install libglu1-mesa-dev freeglut3-dev mesa-common-dev
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 freeglut3-dev : Depends: libgl1-mesa-dev but it is not going to be installed or
                          libgl-dev
                 Depends: libxt-dev but it is not going to be installed
                 Depends: libxext-dev but it is not going to be installed
 libglu1-mesa-dev : Depends: libglu1-mesa (= 8.0.2-0ubuntu3) but 8.0.4-0ubuntu0.4 is to be installed
                             libgl-dev
 mesa-common-dev : Depends: libx11-dev but it is not going to be installed
                   Depends: libdrm-dev but it is not going to be installed
How do I fix this ?
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
You just need to do
sudo apt-get install freeglut3-dev
thefourtheye
  • 4,922
  • 26
  • 32
Just try this:
sudo apt-get install freeglut3 freeglut3-dev
And add the linker for the case of newer versions of Ubuntu
sudo apt-get install binutils-gold
Alaa Ali
  • 32,213
