When going to the boot menu (after pressing option), the Powerbook G4 667MHz detects the installer (either on a CD or flash drive - depending on what I am using), but when I choose the Linux installer the screen flashes and the menu comes back in low resolution. Only the mouse works.
I suspect the firmware is looking for a very specific configuration in the disc and it is not finding it. The same problem happens if I try to boot up the Leopard (OSX 10.5) installer or DiskWarrior 4. However Diskwarrior 3.3 and the Tiger (OSX 10.4) installer boot up without a problem.
It is not the Ubuntu installer because it works fine on an iMac. Maybe there is a way to work on yaboot or GRUB to talk to the Tibook? Any ideas?
The processor is: PowerPC 7440 G4
In the system profiler, I get:
Processor name: PowerPC G4 (2.1)
Boot ROM version: 4.2.9f1
The installer is for PowerPC, and it works fine in my iMac (another PowerPC G4). It seems to be something more specific. I have tried different distros (Yellow Dog, Lubuntu, Debian) and they all have the same problem with this computer, but not with the iMac.
Like I thought, it has to do with yaboot. I restored the image of the installer in another partition of the hard drive and forced the boot from the firmware. yaboot starts and flashes these lines:
loading XCOFF
tsize=28000 dsize=2000 bsize=3a000 entry=5616ecc SECTIONS .text 05600000 05600000 00028000 000000d4 .data 05628000 05628000 00002000 000280d4 .bss 0562a000 0562a000 0003a000 00000000 loading .tex, done loading .data, done clearing .bss, done
After which, it shows the "forbidden/not allowed/cross out circle sign" that indicates that the operating system is in a broken folder or corrupted (I haven't seen that symbol in a while).
I think PowerPCs have a port of Ubuntu. This is a quote:
Desktop CD
The desktop CD allows you to try Ubuntu without changing your computer at all, and at your option to install it permanently later. You will need at least 384MiB of RAM to install from this CD.
There is one image available:
Mac (PowerPC) and IBM-PPC (POWER5) desktop CD
For Apple Macintosh G3, G4, and G5 computers, including iBooks and PowerBooks as well as IBM OpenPower machines.
Can't get Ubuntu 12.04 LTS Live to load properly on Apple iMac PowerPC may prove to be relevant. I'm pretty sure that the port of Ubuntu you're trying to use won't work. As far as I know, there isn't a desktop edition of 12.10 available yet that works on PowerPCs. There is a server edition, and, if you follow the above links, desktop editions of 12.04.
Zanna
  • 72,312
Nil
  • 1,006
The problem is due to the way Open Firmware (in the version installed in these powerbooks) maps the devices.
In order to boot from the CD, you should try going into Open Firmware (reboot computer and press Option-Command-o-f ).
at the prompt, try typing:
boot ide1:2,\install\yaboot
The CD is mapped as ide1 and for some reason it needs to look for the 3rd partition of the CD (didn't you know there was more than one partition in the CD?? Neither did I!!!). that is why you should try to boot from ide1:2
If your powerbook is like mine, you should reach the yaboot prompt (from the CD) with that command, but the installer may not run due to the fact that the screen size is not standard (these laptops use the Ati Radeon video chip but the screen is 1152 x 768) and the framebuffer is not configured by default. I found many suggestions online but failed with all of them.
But there is a workaround: connect an external monitor and try to work from within the system.
I managed to install Lubuntu 10.04 with an external monitor and simply adding: nosplash video=ofonly to the main command (either Linux or Install).
an even better solution: install Debian instead. at least Debian 6 can be installed from yaboot with:
install32 nosplash video=ofonly
Debian doesn't need the external monitor since it configures the screen right away.
Zanna
  • 72,312
