19
Is there a way to rename all files in a directory to lowercase|uppercase?
I am looking for a oneliner command.
I loved TotalCommander's Alt + F7, now I need that functionality in the Terminal.
Pablo Bianchi
  • 17,371
5 Answers5
21
For each file a_file in current directory rename a_file to lower case.
for a_file in *;do mv -v "$a_file" `echo "$a_file" | tr [:upper:] [:lower:]` ;done;
For upper case reverse the arguments to [:lower:] [:upper:]
tr command reference link
Update
For even more control * can be replaced with ls.
For example in a directory containing 1.txt, 2.txt, 3.txt, 1.jpg, 2.jpg and 3.jpg in order to filter only *.jpg files, ls can be used:
for a_file in $(ls *.jpg);do mv -v $a_file `echo $a_file | tr [:upper:] [:lower:]` ;done;
The above code will assign to a_file variable all files with .jpg extension.
Update added -v option to mv command as per sds suggested.
Stef K
  • 4,886
17
There's a more elegant and general utility called prename.
Written by Larry Wall, it comes with perl so it is most likely already available on your system as /usr/bin/prename (if you have setup alternatives is may also be available as /usr/bin/rename symlinked via /etc/alternatives to prename)
Using it you can rename multiple files in one command by providing any perl expression (including but not limited to substitution s/// or char transliteration tr///):
Examples:
# Lowercase all *.JPG filenames:
prename tr/A-Z/a-z/ *.JPG
# Change any 'No' in a filename to a 'Yes':
prename s/No/Yes/g *No*
# increment first sequence of digits in a filename by 3:
prename 's/([0-9]+)/$1+3/e' *[0-9]*
# If a file contains 'aaa', append '.bak' to its name
prename 'if (/aaa/) {$_ .= ".bak"}'  *
And so on.
Another nice thing about prename is that it protects you, in the case of renaming a file to an existing file name.
man prename for more details.
arielf
  • 2,883
Using find
find . -name * -type f -exec rename 'y/A-Z/a-z/' '{}' \;
For find
  • Of course after -name put your pattern.
  • -maxdepth 0: Only current directory.
For rename
  • -n, -nono: No action: print names of files to be renamed, but don't rename.
  • y/source/dest/: Transliterate the characters in the pattern space which appear in source to the corresponding character in dest.
Pablo Bianchi
  • 17,371
Using mmv to convert matched string to uppercase:
$ mmv -r '*' '#u1'
Its important to quote the pattern otherwise it will expand the wildcard instead.
Expanding my comment to make formatting clearer, this code is based on the solution above, expanded to work with filenames that contain spaces and filenames that are already lowercase.
This will rename everything in folder/ to lowercase.
ifs=$IFS; IFS='\n'; for file in folder/*; do mv -nv "$file" "`echo "$file" | tr [:upper:] [:lower:]`"; done; IFS=$ifs
"folder/*" can be replaced with other ways to list a file, e.g.
`find folder -type f`
To handle filenames with spaces, I have
  1. ...set the separator (IFS) to newline and reset later
  2. ...escaped the filenames in the mv command
If some filenames are already lowercase, mv would complain that source and destination are the same. This has been prevented by the "-n" option.
I have also added the "-v" option to see which files were actually renamed.
jcsjcs
  • 71
