18
The simple keyboard combination of Alt-Tab to switch between applications doesn't work.
I have followed this answer but it doesn't answer the question as I want to switch to another application, not display applications and then have to select it via the mouse as it defeats the purpose of the quick switch to the other application.
There is also mention of updating the Keyboard shortcut settings. My keyboard combination is set to the Alt-Tab in the shortcut section and it doesn't switch applications. Seems the setting is ignored as I changed it to another keyboard combo and it just doesn't switch applications.
Meer Borg
  • 5,003
Seems Application Switching is turned of by default.
To activate it you need to run the following command
ccsm
That will bring up CompizConfig Settings Manager.
  • Go to the Window Management section.
  • Check off ✔ Application Switcher.
Then the Alt+Tab will work.
Require installation of the compiz-plugins-extra package.
Meer Borg
  • 5,003
The solution in Meer Borg's answer made my computer very slow.
I instead checked the:
✔ Static Application Switcher
That also solves this problem.
mace
  • 379
Using the Static Application Switcher made my Alt+Tab work, but Alt+Shift+Tab was somehow bound to a different application switcher, which meant that I could not go back and forth by keeping the Alt key down, and alternating between Tab and Shift+Tab.
I finally managed to get it working by removing Alt+Shift+Tab from switch-applications-backward:
gsettings set org.gnome.desktop.wm.keybindings switch-applications-backward "['<Shift><Super>Tab']"
zpon
  • 131
install,
sudo apt-get install compizconfig-settings-manager
sudo apt-get install compiz-plugins
if you didnt install plugin you wont be able to see application switcher
type ccsm in terminal or do alt+F2 search ccsm
and select Window management , check (enable) application switcher checkbox.
if it prompt for conflicts, say resolve conflicts and select things which is selected which is set anyway
done..
now you can do alt+tab
you can change this shortcut in same ccsm,
-> Scroll down or filter to "Ubuntu Unity Plugin". -> Choose the tab "Switcher". -> click alt-tab and shift-alt-tab key bindings. ("Key to switch to the previous window in the Switcher") Click the "Back" button.
