By normal brightness controls I mean the accelerators on my laptop's keyboard that seem to integrate with Unity.
In a dark room, my screen is quite bright, even on the lowest setting. Can I override this?
I tried setting it explicitly via both:
sudo echo 500 > /sys/class/backlight/acpi_video0/actual_brightness
sudo echo 500 > /sys/class/backlight/intel_backlight/actual_brightness
But I get a permission denied error.
When at the lower bounds via my keyboard's brighness controls, acpi_video0/actual_brightness is 0, and intel_backlight/actual_brightness is 729. Can I set the latter value to be even lower?
Drew Noakes
  • 5,878
Your command gives elevated permissions to the echo command (which doesn't need them), but not to the part that redirects the output stream to the root-owned file (which does)
In a terminal, you can either do
echo 7 | sudo tee /sys/class/backlight/acpi_video0/brightness
which gives the elevated permission to the bit that really needs it, or
sudo sh -c "echo 7 > /sys/class/backlight/acpi_video0/brightness"
which runs the whole command in a sudo shell
Vivek Rai
  • 166
I created a slider tool based on the information presented here in the question/answers:
It provides an alternative slider to control backlight with finer control.
oblitum
  • 1,727
Turns out that the two items I show in the question are read only for all users.
However /sys/class/backlight/intel_backlight/brightness is not. So, the following works:
sudo su
echo 500 > /sys/class/backlight/intel_backlight/brightness
Be aware that echoing a zero value makes the screen is unreadable :)
You may have a different name for your device (instead of intel_backlight).
Also, performing the above using sudo echo ... doesn't work. Can someone explain why I have to do sudo su first?
EDIT @Vivek's answer explains this.
Drew Noakes
  • 5,878
