171
The difference between vim-gtk and vim-gnome has been discussed here.
Ubuntu usually offers more than these two options for vim, e.g.:
  • vim-nox
  • vim-athena
  • vim-*
It is not clear which vim package have which dependecies and which one is preferable to use on one's system. I keep my vim configuration files (~/.vim folder) on GitHub and clone it on any system I have to work on. They work with vim-gnome but will they work with any of these distributions?
Can we have the major differences listed out between all of the possible vim candidates available on Ubuntu so one can make an informed decision?
user_
  • 49
Dilawar
  • 1,811
Including the vim package, there appear to be at least six "vim-variants" (not including available documentation, or plugin packages) as well as the main vim package in both the main and universe repositories.
Below is a brief summary of each (links go to package description and dependencies in Ubuntu LTS release 20.04 "Focal"):
Vim compiled and set up with a rather standard set of features. This package does not provide a GUI version of Vim or scripting language support. See the other vim-* packages if you need more (or less).
In order to install this package, run sudo apt-get install vim
This package allows the entering of Kanji from the console.
In order to install this package, run sudo apt-get install jvim-canna
Depends upon the libcanna1g library
Does not appear to support Perl, Python, Ruby, or TCL scripting.
  • vim-athena - enhanced vi editor - compiled with an Athena GUI
    This package is compiled with the Athena GUI as opposed to GTK+ or Gnome.
    See this askubuntu answer for additional details.
    In order to install this package, run sudo apt-get install vim-athena
    Supports Perl, Python, Ruby, and TCL scripting.
  • vim-gnome/vim-gtk3 - enhanced vi editor - compiled with a GNOME GUI (GTK2 before 17.10, GTK3 from 17.10)
    In order to install this package, run sudo apt-get install vim-gnome
    Depends upon the libgnome2 library
  • vim-gtk - enhanced vi editor - compiled with the GTK2 GUI
    Used in KDE/Kubuntu-like environments
    In order to install this package, run sudo apt-get install vim-gtk
  • vim-nox - enhanced vi editor
    Like vim-tiny, vim-nox is a minimal vim installation and does not have a GUI. It comes with mouse support, but no clipboard support, IIRC.
    In order to install this package, run sudo apt-get install vim-nox
  • vim-tiny - enhanced vi editor - compact version
    vim-tiny is included as the default vim on Ubuntu distributions and comes with many optional features disabled(e.g. multi-level undo).
    See this askubuntu answer for details on its feature set(or lack thereof).
    In order to install this package, run sudo apt-get install vim-tiny
    Does not support Perl, Python, Ruby, or TCL scripting.
    As close to being vi without being vi.
Locally, to see which features are supported in a particular installed vim package, running the following command: vim --version will provide a list of features included(or excluded) in the particular package.
For example, on my system I can run either vim --version, vim.tiny --version, or vim.athena --version to see the differences in their respective supported features. The Debian/Ubuntu /etc/alternatives system determines which vim package executes when you runvi or vim, see What is etc/alternatives used for?
Python support
Before 16.04, the above packages (other than vim-tiny) included Vim with scripting support for Python 2. In 16.04, they all support Python 3, and there are corresponding *-py2 packages (vim-gnome-py2, for example) which provide a Vim command with Python 2 support. Both can be installed together, and the commands will be, for example, vim.gnome and vim.gnome-py2 respectively. Otherwise, the *-py2 packages provide the same feature set as the corresponding packages. Python 2 support was removed after 16.04.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
