When attempting to run a remote binary using sudo on the remote box:
ssh remotehost "sudo ./binary"
I see this error:
sudo: no tty present and no askpass program specified
How can I work around this?
I see this error:
A simple way is to specify -t:
ssh -t remotehost "sudo ./binary"
From the man page:
Force pseudo-tty allocation. This can be used to execute arbitrary screen-based programs on a remote machine, which can be very useful, e.g. when implementing menu services. Multiple -t options force tty allocation, even if ssh has no local tty.
I cannot explain exactly why this works, and there may be a better way. I'd like to hear about it if so :)
@psusi explains why this works in a comment below.
As an alternative, try:
sudo -S ./[yourExecutable]
This directs sudo to read the password from the standard input, stdin.
In chroot environments, these other answers may not work correctly ... perhaps because:
For example: Manually installing / repairing linux or the bootloader, using a chroot environment, (such as Archlinux and arch-chroot).
It fails, because sudo is trying to prompt on root password and there is no pseudo-tty allocated.
You've to either log-in as root or set-up the following rules in your /etc/sudoers
(or: sudo visudo):
# Members of the admin group may gain root privileges
%admin ALL=(ALL) NOPASSWD:ALL
Then make sure that your user belongs to admin group (or wheel).
In my case I've received this error because I wasn't specifying a command that I would like to use as root in the sudoers
Something like
/etc/sudoers.d/myuser:
myuser ALL=(root) NOPASSWD: \
/bin/ls -la
worked for me
You need to define terminal/application that will read the password. There are two variants:
export SUDO_ASKPASS=/usr/libexec/openssh/ssh-askpassvim /etc/sudoers (Defaults visiblepw)You can also create a file like "sudo_shutdown" in /etc/sudoers.d, with content:
# Allow admins to shutdown without pass
%adm ALL=(ALL) NOPASSWD: /sbin/shutdown
This allows users which are in the adm group to shutdown without a password.
