I've got a mail with eml file attached. I'm using Thunderbird but it doesn't open it.
Could anybody suggest program to open eml files?
Update:
I don't want to import my mailbox I want only read the content of eml file.
Update:
I found that these instructions to be very helpful
For the love of command line tools, instead of the visual/heavy Thunderbird/KMail or Evolution.
sudo apt-get install mpack
Then to extract the eml contents
munpack 1.eml
In my case I need to use -t to get past the following error messages
munpack ./ServerPerformance.eml
tempdesc.txt: File exists
image001.jpg.2 (image/jpeg)
I then get every thing out like this.
munpack -t ./ServerPerformance.eml
part1 (text/plain)
part2 (text/html)
image001.jpg.3 (image/jpeg)
I saved attachment after I opened with File->Open Saved Messages... menu in Thunderbird.
If you have Chromium you can drop eml files on it and it will show properly. On my Raspbian Chromiun is default.
You can use MHonArc (what a website ) to convert the .eml files to HTML, if you want something command-line-y but pandoc isn't working out for you (it didn't for me):
sudo apt install mhonarc
mhonarc -single file.eml > file.html
You can open an .eml file simply with Thunderbird these days. No plug-in necessary.
sudo apt-get install thunderbird
In Thunderbird you can view it, print it, reply/forward/redirect, etc.
Go to File -> Open -> Saved Messages... or just double-click on an .eml file and select Open With... -> Thunderbird.
Install this plug-ins here. (see important note you can import EML files in IMAP accounts).
To install the extension, follow this procedure:
Restart Thunderbird.
Go to Tools ➜ ImportExportTools ➜ Import eml File and find your file.
I've got the same issue in my company: one operator was forwarding a mail using Windows 10 Mail software and the other operator was unable to open the attached .eml file with Thunderbird.
Simply let Thunderbird re-forward the message back to the Thunderbird operator, like if you're forwarding the message to yourself, fixed the issue, actually i was able to see every attachment of the original message plus the true .eml file content.
