How I can install Emerald on Ubuntu 12.10?
jokerdino
  • 41,732
I had to manually compile it from the last sources I found, since I wasn't able to find any deb with a newer version of it.
First, you need to install the dependencies:
sudo apt-get install git autoconf libtool libwnck1.0-cil-dev libwnck-dev intltool libdecoration0-dev
Download the package:
http://cgit.compiz.org/fusion/decorators/emerald/snapshot/emerald-0.9.5.tar.gz
Uncompress it and compile with these commands:
cd emerald-0.9.5
./autogen.sh && make clean && make distclean && ./configure --prefix=/usr && make && sudo make install
sudo chmod +x /usr/bin/emerald
To run it, simply execute:
emerald --replace
If it works, you can set this last command in the "Window Decorations" section in compiz configuration with ccsm.
