Here's the situation:
I start my main computer from another pc via wake on lan "wakeonlan ". All works fine. When I'm done doing what I did, I run "sudo shutdown -h now" (in the ssh terminal in which I was working) to shutdown the computer. But instead of shutting down, it reboots. I then have to reconnect to it via ssh and run the shutdown command again, and then it shuts down and stays off. I can then start it again via wake on lan...
does anyone know, why my computer actually reboots when I type "sudo shutdown -h now" when started via wake on lan?
Some information about the computer:
Ubuntu 13.04
Moterboard: Gigabyte GA-Z77X-UD3H
Ethernet Controller (as reported by "lspci"): Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet (rev c0)
patsee
  • 143
There's one dirty solution
a) create /etc/init.d/reshutdown with the contents
#!/bin/sh
# force shutdown (due to bug in wakeonlan)
case "$1" in
reshutdown)
  touch /home/shutdown.chk
  shutdown -r now
start)
 if [ -f /home/shutdown.chk ];
 then
    rm /home/shutdown.chk
    shutdown -h now
 fi
esac
b) Execute: sudo chmod ugo+x /etc/init.d/reshutdown
b) Execute: sudo update-rc.d reshutdown start 1 1 2 3 4 5 6 .
c) Then to shutdown execute: sudo service reshutdown reshutdown
I had this issue too, using the Intel DQ77MK motherboard, which has 2 onboard Intel GB ethers. I fixed it by enabling the power bios entry "Native ACPI OS PCIe Support", which I guess allowed Ubuntu to reset the flag saying WOL has been triggered, probably with it disabled Ubuntu was not allowed by the BIOS to reset the flag.
mal
Try sudo poweroff.
It works better with WOL for me.
vikas112
  • 131
