I'm using a Lenovo x230 laptop which features a touchpad and a trackpoint. I love the trackpoint and dislike the touchpad -- I continuously hit it with my thumb.
I would like to disable the touchpad, but leave everything else working. I've tried using xinput by putting the following in my .xinitrc:
$ xinput --disable 'SynPS/2 Synaptics TouchPad'
This works, however, after a few minutes, the touchpad becomes enabled again. I'm not sure why this is happening. Is this the best way to persistently disable the touchpad?
oneself
  • 275
The following methods will ensure your changes persist as long as you use gnome:
  1. Install and run dconf-editor (if you're on 12.10, dconf-editor might be pre-installed):
    $ sudo apt-get install dconf-tools
    $ dconf-editor
  2. Go to the following settings directory:
    org.gnome.settings-daemon.peripherals
  3. Under touchpad, uncheck the touchpad-enabled checkbox.
If you prefer not to meddle with dconf-editor's GUI, run the following command instead:
gsettings set org.gnome.settings-daemon.peripherals.touchpad touchpad-enabled false
oaskamay
  • 657
