The other day I applied updates and broke my ability to watch amazon videos on my computer. I am not alone. See the amazon forum post.
How can I rever to the previous version of Flash?
Here's what I've tried so far. Using
tail -10 /var/log/dpkg.log
I found this line that looks like the culprit on my system:
2013-04-10 16:31:56 status installed flashplugin-installer:amd64 11.2.202.280ubuntu0.12.10.1
At this point, I'm not sure what to do. And I think the issue is complicated by the fact that the package I'm referring to is an installer, not an actual plugin.
snowguy
  • 6,310
Here is the fix:
  1. Close running instances of your browser.
  2. If you don't already have synaptic package manager installed (it isn't by default) install it. From the terminal type:
    sudo apt-get install synaptic
  3. You will also need to install "hal" and "hal-info", unless already installed:
    sudo apt-get install hal hal-info
  4. Start Synaptic Package Manager
  5. In the top right of the application is a search box. Search for "flashplugin-installer"
  6. Highlight the package and press Ctrl + E
  7. The "Force version" window should open
  8. Pick version 11.2.202.243 instead of the currently installed 11.2.202.280
  9. Apply changes by clicking the button that says "Apply" with a check mark under it.
  10. With the package still highlighted, select from the top menu: Package->Lock Version
  11. Close Synaptic and open a terminal
  12. We need to remove old cached versions of the plugin. First type:
     cd ~/.adobe/Flash_Player
  13. Next type:
     rm -rf NativeCache AssetCache APSPrivateData2
  14. You can now close the terminal and reopen your browser
Thanks to Rob S for the instructions on how to do this. The above instructions are his with only slight modifications. Additionally, the last few instructions are from the Arch Linux Wiki.
Seth
  • 59,332
snowguy
  • 6,310
I use the adobe-flashplugin package instead of the flashplugin-installer package, so I fixed it a different way; I downloaded the old .deb file for the adobe-flashplugin package and installed it with dpkg:
wget http://launchpadlibrarian.net/134077901/adobe-flashplugin_11.2.202.275-0precise1_amd64.deb
sudo dpkg -i adobe-flashplugin_11.2.202.275-0precise1_amd64.deb
I'm using 12.04 (precise); you can find the appropriate download urls for other ubuntu releases by following the links here:
https://launchpad.net/ubuntu/+source/adobe-flashplugin
One big drawback to doing it like this is that apt-get will refuse to install or update any other packages until you upgrade your adobe-flashplugin package back to the latest version with this command:
sudo apt-get -f upgrade adobe-flashplugin
Hopefully amazon fixes their flash player soon.
