Is it possible to tweak settings if and only if the computer starts on battery power?
Why?
I usually work without battery, but when I use a battery I want it to last as long as possible. For that purpose I use little tweaks (granola for minimal power consumption, switching off wifi and bluetooth, and brightness settings).
What?
Whenever I boot my laptop on battery I have to manually tweak all these settings. In the beginning that was OK, but now I want these tweaks to be done automatically. What I want to be tweaked automatically when booting on battery power is
  1. setting the laptop in flight mode (no wifi nor bluetooth)
  2. dimming the screen to 50%
  3. disabling all usb inputs (I often leave a few things in usb slots, but I do not want them activated)
  4. set the power mode in granola to minimal consumption (this needs sudo).
Any ideas? A script that runs automatically when logging in on battery? Anything?
don.joey
  • 29,392
You can insert your custom battery-saver commands to an executable file like this under folder "/etc/pm/power.d":
#!/bin/bash
if on_ac_power; then
    : # Do nothing
else
    rfkill block bluetooth # Turn OFF bluetooth
fi
exit 0
You can see a list of other options using PowerTOP utility.
Sadi
  • 11,074
