I download this package and following the instructions on the website i untared its package in /usr/local/share and used ./install command to install it.
now I need to remove it. Is there anyway to do that ? If it needs them I still have the installation files.
this is the website
Eliah Kagan
  • 119,640
If there is no uninstall option you need to manually remove the files.
Most (if not all) of the files will be installed inside a directory (from the readme I would assume it is called ns-allinone-2.35) at the path you ran ./install. Simply use a rm -rf to remove that directory and it will be gone.
Now for 1 extra step: during installion either the installer added some links to ~./bashrc or you edited them in yourself. So do a (backup at the 2nd command):
cd ~
cp  .bashrc .bashrc_old
gedit ~/.bashrc
and have a look for anything related to ns-allinone-2.35 and remove it. Be careful; if you mess up it might be problematic. After editing you need to parse the changes:
source ~/.bashrc
Rinzwind
  • 309,379
All you need to do is delete the ns-allinone-2.35 directory.
When you ran install from within that directory, it installed everything into the same directory.
The installer doesn't appear to make any changes to your ./bashrc file on it's own, but if you added any of the changes they recommend, then, of course, you will also need to undo those changes.
chaskes
  • 15,536
