How would I go about installing Ubuntu 32 and 64 bit 12.10 on the same disk? I would really like to do this if you could help. I'm on Ubuntu 12.10 64bit ATM if that helps.
Edit: What I meant was installing the install cd for both 32 and 64bit on the same disk not the OS itself.
On a dvd-r
Here is wqhat I'm looking for:
Ubuntu 32 and 64 bit installation disk on 1 DVD -r so when a person puts the dvd in and restarts computer they enter a menu and have to chose which OS they want to install , the 32 bit OS or the 64 bit OS of Ubuntu 12.10
Alvar
  • 17,038
Robert Hickey
  • 41
The 32bit install will actually run fine on most 64bit computers, so if you want to have a single DVD that can install onto "most" computers then you should just use the 32bit version only.
robru
  • 674
As far as I know this isn't a possibility. However, it is possible to boot multiple operating systems from one USB drive. I use a utility called MultiSystem (instructions here) which lets you drag and drop ISOs onto a USB and creates a GRUB bootloader on the USB to choose which system you actually want to boot.
Alex
  • 1,508
  • 16
  • 29
