When I log into gnome in Ubuntu 12.04, I can type the following on the command line to open a pdf:
evince mypdf.pdf
However, the following does not work.
su
evince mypdf.pdf
That gives the following error:
(evince:1368): EggSMClient-WARNING **: Failed to connect to the session manager: None of the authentication protocols specified are supported
               ** (evince:1368): WARNING **: The connection is closed
                                 No protocol specified
                                 Cannot parse arguments: Cannot open display:
How can I fix it so that changing users on the command line does not break GUI applications?
merlin2011
  • 599
  • 17
Generally speaking you use gksu
gksu evince mypdf.pdf
See https://help.ubuntu.com/community/RootSudo#Graphical_sudo
Panther
  • 104,528
