The Hacking file for Unity says:
Internal Documentation can be built for Unity by having doxygen installed and running make doxygen.
I'm not familiar with doxygen and could use some help in the specific command(s) to use.
I downloaded the Unity source using: bzr branch lp:unity and ran doxygen Doxyfile.in.
It generated api-doc/html with a number of files, but index.html loads an empty framework.
I read the man file and the online manual/faq but am still not sure what I need to do.
Zanna
  • 72,312
chaskes
  • 15,536
I got this working. I had assumed that the Doxyfile.in file was setup for any system and that all I had to do was run doxygen Doxyfile.in.
In fact, I discovered that doxygen expects to be run as cmake target, but I wasn't looking to do the entire build just yet.
To run doxygen as a stand alone process, I needed to edit the Input section of the Doxyfile.in with the actual path to the source file directory, commenting out the existing path variables that are there for use with the make file.
After that, doxygen Doxyfile.in worked fine.
chaskes
  • 15,536
