The usual way to remove services from startup scripts is to remove it from starting up in the first place (man update-rc.d). Meaning removing the symbolic link to /lib/init. In this case executing should do the job:
update-rc.d -f bluetooth remove
But why this does not work in the case of bluetooth deamon? Can someone explain a little deeper what is going on? And if I remove the link by force is the bluetooth chip/hardware still eating my battery?
Here is what happens:
    sudo update-rc.d -f bluetooth remove
 Removing any system startup links for /etc/init.d/bluetooth ...
    sudo ls -la /etc/init.d/ | grep bluetooth
lrwxrwxrwx   1 root root    21 Mar 21  2012 bluetooth -> /lib/init/upstart-job*
So the link remains.
And there seems to be other confused people [1] [2] trying different solutions to the bluetooth behaviour.
[1] How can I deactivate Bluetooth on system startup? [2] How to boot with bluetooth turned off
TipiT
update-rc.d is indeed the usual way...to change a sysvinit (not upstart, not systemd) init priority.
Those sysvinit scripts are in /etc/init.d
But Upstart doesn't use update-rc.d nor /etc/init.d (except for legacy compatibility). So the short answer to your question is that the bluetooth software uses Upstart jobs instead of sysvinit scripts.
One good way to permanently disable an upstart job is to rename the .conf file.
Example:
sudo service bluetooth stop
sudo mv /etc/init/bluetooth.conf /etc/init/bluetooth.conf.disabled
You can re-enable by changing the name back to bluetooth.conf without a restart.
sudo mv /etc/init/bluetooth.conf.disabled /etc/init/bluetooth.conf
sudo service bluetooth start
You change the dependencies of automatic startup by editing the .config file.
user535733
  • 68,493
