I have a Toshiba L500-128 laptop with Ubuntu 12.04 64 bit OS, the only problem I have is the overheating of my CPU, with temperatures from 70 to 90 C.
I think that this is related to the usage of the CPU fan. How can I fix it ?
Braiam
  • 69,112
user148108
5 Answers5
First of all that's nothing to worry about. I would though agree with bodhi.zazen, in trying to clean the laptop. I would recommend getting a can of compressed air, and try to clean the CPU fan. Now according to Intel, that CPU, is rated at 105°C. See Here. So 70°C to 90°C to is OK, and it should drop down once the CPU fan is cleaned.
Mitch
  • 109,787
Unless the system shuts down, then it isn't overheating. Those temperatures are normal when under load.
psusi
  • 38,031
In some cases fan speed is calculated at boot time, so try to wait the laptop to heat a bit, then restart it.
The fan speed will be, hopefully, recalculated and the problem solved, since the microprocessor is never too cold. I'm not joking, try it!
  1. Try installing the proprietary graphics driver.
    I had the same issue with the free drivers (some version of ubuntu ago), I saw great change after changing to the official (proprietary) drivers.
  2. Cleaning the cooling system of your laptop will definitely really improve the situation. Dust and hair form a thick "blanket", not allowing the air pass. The laptop must be opened. Check if it is in warranty. If it is not, you may open it. Check for the service manual or relevant videos on YouTube.
MakisH
  • 1,120
I had a toshiba with similar issues. What I discovered was that it wasn't always the cpu, but the gpu. You usually feel the heat on the left side of the hand rest area of the keyboard. After a LOT of research, I discovered that it was an issue with the DSDT - Toshiba doesnt generate their own for their laptops, so Microsoft ends up producing the DSDT file used on the system. I was able to rectify by decompiling the DSDT and making some manual changes to it and recompiling it, then, added it back to the linux boot loader and that fixed it.
If you want to, research DSDT files and their relationship to system hardware controls - especially regards to regulating the fan.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Ade
