I recently Installed 12.10 version and I loved it! But the there's something weird with Wallpapers. As long as I use a wallpaper from the /usr/share/backgrounds folder (I use the "appearance" dialog box), this wallpapers appears also on my welcome (login) screen. But when I try to use a wallpaper from my pictures folder (again using the "+" button from the appearance dialog box), my login screen has the standard ubuntu 12.10 wallpaper. Is there anything I can do to fix this?
Thanks in advance!
Jorge Castro
  • 73,717
When you copy the picture to /usr/share/backgrounds you also need to change the permissions - read-write for owner and read-only for others.
This can be accomplished by running the following command in a terminal:
sudo chmod 644 filename
green
  • 14,406
Ubuntu tweak can do this:
My login now shows dragonlady.
Rinzwind
  • 309,379
