I keep getting this error:
Package: /var/cache/apt/archives/firefox_20.0+build1-0ubuntu0.12.10.3_amd64.deb
Error: trying to overwrite '/usr/share/applications/firefox.desktop', which is also in package kubuntu-firefox-installer 12.04ubuntu1
I am only trying to install Firefox as a browser. Interestingly, it will not let me remove the "Firefox Installer" either. Any suggestions?
Nicholas
Thus is an issue with the Kubuntu Firefox installer. The easiest way to fix this is to use Muon package manager to remove the package called kubuntu-firefox-installer.
Then you should be able to install Firefox without a problem. If it still doesn't work, use Muon to install the package firefox-globalmenu.
That took care of my problems.
BuZZ-dEE
  • 14,533
DWcoder is correct just remove the kubuntu-firefox-installer package, but when you install firefox, firefox-globalmenu is a depend of firefox so it will be installed anyway.
-1
It worked.
Removing Firefox Installer. In Terminal:
sudo apt-get install kubuntu-firefox-installer
Then type your sudo (your user password) password to install Firefox and Chromium.
Wilf
  • 30,732
Filipe
