I have accidentally changed the root user from administrator type to basic type in the user account page, and now i have no whatever root previligaes on the system, how i can switch back to administrator type?
Kaspro
  • 89
Assuming you have not actually changed the root user but removed the first user from the list of administers then this is relatively easy to fix.
Press CTRL+ALT+T and enter id
You should see something similar to.
~$ id
uid=1000(warren) gid=1000(warren)groups=1000(warren),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),109(lpadmin),124(sambashare)
If this shows sudo you should be an administrator. In Ubuntu prior to 12.04 the group was admin If not this is the problem.
First you need to boot to a root shell if you don't normally see grub when you boot hold SHIFT.
You should see something like this:
grub
Select recovery mode, then drop to root shell.
grub2
Finally mount the file system read write
mount -o rw,remount /
If the problem was that you were not in the sudo group it can be fixed with
usermod -aG sudo warren
replacing warren with your user name. If you are not sure what the user name should be it was the uid= field from the id command you ran earlier.
replace sudo with admin if you are using a version of Ubuntu prior to 12.04.
Another less likely possibility is that you have changed the sudoers file
If this is the problem then enter
visudo
Edit this file to look like this (12.04 default):
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults    env_reset
Defaults    secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
Warren Hill
  • 22,412
  • 28
  • 70
  • 88
At the grub boot selection screen (if this doesn't show up hold shift at boot) select ubuntu recovery mode and press enter, then select root terminal (or something similar it may be called root shell) from the list of options. Then type mount -o rw,remount / to gain read/write access to the filesystem. Then type adduser adminusernamehere sudo to give the admin user that you changed to standard sudo (root) privileges.
-2
Go to the User Accounts.
Users
Image from Eliah Kagan's answer to How to manage users and groups?
Then, click on 'Advanced Settings'.
Advanced Settings
Image from How to create a Ubuntu 12.04 x64 LTSP server with 32bit thin clients by The Fan Club
Then, tick any boxes you want. The one you want though, is Administer the System.
Hope this helps!!
horIzoN
  • 1,084
