I'm attempting to set up a VPN from my Android phone to my home computer using pptpd on Ubuntu 12.10. I have so far done the following.
Setup a virtual NIC like this...
cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto eth0:0
iface eth0:0 inet static
address 192.168.0.1
netmask 255.255.255.0
and then configured pptpd like this... (commented line has been omitted to save space)
cat /etc/pptpd.conf
option /etc/ppp/pptpd-options
debug
logwtmp
localip 192.168.0.1
remoteip 192.168.0.100-200
name pptpd
refuse-pap
refuse-chap
refuse-mschap
require-mschap-v2
require-mppe-128
proxyarp
nodefaultroute
debug
lock
nobsdcomp
/etc/ppp/chap-secrets
andreas         *       a5okg4b99               *
But all I get from syslog even with debug turned on is..
Apr  8 14:53:25 Ellit pptpd[19488]: MGR: connections limit (100) reached, extra IP addresses ignored
Apr  8 14:53:25 Ellit pptpd[19489]: MGR: Manager process started
Apr  8 14:53:25 Ellit pptpd[19489]: MGR: Maximum of 100 connections available
and when I finaly try to connect with my phone all it says is...
Apr  8 14:29:43 Ellit pptpd[25180]: MGR: dropped small initial connection
I don't realy know where to go from here... have I made and error in thinking that a virtual NIC will work and why can't I get any debug information even when I asked for it in the configurations?
EDIT: The last line when I try to connect seems to appear somewhat random, I can right now not reproduce it but I fairly sure it related to my connection attempt before and I have not changed anything from then. I'm starting to suspect that my Android ISP is blocking VPN but that would be... insane.
Aoaoaoappa
I had a similar problem. Basically, I found that commenting out require-mppe-128(#require-mppe-128) allows Android based devices to consistently connect to a PPTP based server.
That will however leave your connection unencrypted.
papukaija
  • 2,425
Okkio
