I'm using btrfs for my home directory, which spans multiple devices. In total I should have around 7.3TB of space - and that's what df shows, but I ran out of space after using only 5.7TB of data:
# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sdd3 7.3T 5.7T 63G 99% /home
btrfs has this to say for itself:
# btrfs fi df /home
Data, RAID0: total=5.59TB, used=5.59TB
System, RAID1: total=8.00MB, used=328.00KB
System: total=4.00MB, used=0.00
Metadata, RAID1: total=11.50GB, used=8.22GB
Which is weird, because there should have been enough partitions to support 7.3TB (also, the btrfs data configuration should have been "single" and not RAID0).
Here is what btrfs show says:
# btrfs fi show
Label: none uuid: 2dd4a2b6-c672-49b1-856b-3abdc12d56a5
Total devices 9 FS bytes used 5.59TB
devid 2 size 303.22GB used 303.22GB path /dev/sdb1
devid 3 size 303.22GB used 303.22GB path /dev/sdb2
devid 4 size 325.07GB used 324.50GB path /dev/sdb3
devid 1 size 2.73TB used 1.11TB path /dev/sdc1
devid 5 size 603.62GB used 589.05GB path /dev/sdd1
devid 6 size 632.22GB used 617.65GB path /dev/sdd2
devid 7 size 627.18GB used 612.61GB path /dev/sdd3
devid 8 size 931.51GB used 931.51GB path /dev/sde1
devid 9 size 931.51GB used 931.51GB path /dev/sde2
As you can see, devid 1 (which is the last disk I added) has only 1.11TB used out of 2.73TB available in the partition (its a supposedly 3TB drive, but only 2.7TB usable :-[ ).
I've searched far and wide but couldn't figure out how to make btrfs use more of the partition. What am I missing?
Notes:
- I'm using Ubuntu 12.04.2 with the current kernel 3.2.0-23.
- This is after I've ran
btrfs fi resize max /homeandbtrfs fi balance /home
