I was setting up a kiosk per this tutorial http://www.instructables.com/id/Setting-Up-Ubuntu-as-a-Kiosk-Web-Appliance/?ALLSTEPS
I have hit a problem with the kiosk.desktop file since it is not autorunning when i login to the kiosk account. I cannot figure out why. I have spent extensive hours googling the problem from several angles and am at a point where I can't get it without help.
my kiosk.desktop file is located at /usr/share/xsessions/kiosk.desktop and it reads as follows.
[Desktop Entry]
Encoding=UTF-8
Name=Kiosk Mode
Comment=Chromium Kiosk Mode
Exec=/usr/share/xsessions/chromeKiosk.sh
Type=Application
do I have any typos or something that is wrong in that regard? I have also included my bash file to see if the problem is there not with the .desktop file.
#!/bin/bash
xscreensaver -nosplash &
width=`xrandr | grep \* | head -n1 | cut -d' ' -f4 | cut -d'x' -f1`
height=`xrandr | grep \* | head -n1 | cut -d' ' -f4 | cut -d'x' -f2`
echo $width,$height
cat ~/.config/chromium/Default/Preferences | perl -pe     "s/\"work_area_bottom.*/\"work_area_bottom\": $height,/" > /tmp/tmp.$$
cp /tmp/tmp.$$ ~/.config/chromium/Default/Preferences
cat ~/.config/chromium/Default/Preferences | perl -pe "s/\"bottom.*/\"bottom\":     $height,/" > /tmp/tmp.$$
cat ~/.config/chromium/Default/Preferences | perl -pe     "s/\"work_area_right.*/\"work_area_right\": $width,/" > /tmp/tmp.$$
cat ~/.config/chromium/Default/Preferences | perl -pe "s/\"right.*/\"right\": $width,/"     > /tmp/tmp.$$
mv /tmp/tmp.$$ ~/.config/chromium/Default/Preferences
while true; do chromium-browser %u --kiosk --start-maximized; sleep 5s; done
skids89
  • 131
probably your script does not have execute permissions
chmod 755 /usr/share/xsessions/chromeKiosk.sh
Parto
  • 15,647
Niels
