Can ubuntu 64 bit run ubuntu 32 application?
Now all our pcs and laptop are i7, 16GB memory.
Yes it can. The only thing you will start seeing is that any 32 Bit app will end with ":386". Here is an image to give you an idea:
As you can see, you ca try to install skype using the 32 bit version skype:i386). Same goes for pidgin and any other app that has a 32 bit version in a 64 bit system. Most apps do. If the 64 bit version is not available, they will most likely fallback to the 32 bit one.
Yes, assuming the requisite 32-bit dependencies of the application are installed. There are some applications which are 32-bit only, but installable and usable on 64-bit Ubuntu, from the partner repository.
You can't mix architectures within the same process though, so a 32-bit program can't load 64-bit shared libraries, or vice versa.
