I'm trying to build an ubuntu embedded linux kernel for Beaglebone.
Part of the build has a dependency for ia32-libs. When I try to install it it say it needs ia32-libs-multiarch.
But it says its not installable! (see below). I have tried other solutions from this forum without success.
Can someone explain what is happening and what I can do about it?
ian@ubuntu:~/beaglebone2/linux-dev$ sudo apt-get install ia32-libs
Reading package lists... Done
Building dependency tree
 ia32-libs : Depends: ia32-libs-multiarch but it is not installable
You can find an answer here What happened to the ia32-libs package?
You can still install it using synaptic
sudo apt-get install synaptic
then just find your package there
Geo
  • 1,315
