I'm trying to "try" Ubuntu on my Windows 7 laptop and I installed 12.10 to a USB stick. I changed my boot preferences to boot to USB first. It boots from USB and I get a screen that says "SYSLINUX 4.86 EDD 2012-18-13 Copyright (C) 994-2012 N. Peter Anvin et al" and it just sits there and doesn't go past that screen.
Ben
1.) What application did you use to burn the image to the usb-stick? There are several programms out there (xboot, linux live usb creator, unetbootin, etc.), take a look at this site for more: http://www.pendrivelinux.com/
2.) Have you tried another Linux Distribution too?
3.) Have you downloaded the right version (32-bit/64-bit)?
1) Did you md5sum check the downloaded iso? See https://help.ubuntu.com/community/HowToMD5SUM Check the number against the listing in the link for your release listed at http://releases.ubuntu.com under the MD5SUMS link.
2) If using a CD/DVD, did you burn the disc as slowly as possible? See https://help.ubuntu.com/community/BurningIsoHowto
3) Did you select the media check before trying to install? https://help.ubuntu.com/community/Installation/CDIntegrityCheck
4) Did you ever do a "memory check" (another live-media menu choice) on your PC? Doing the above can save you a lot of time struggling with a bad install media.
ubfan1
  • 19,049
