You could try this without editing ~/.Xdefaults, by running:
xterm -xrm 'xterm*allowWindowOps: true'
Then, in new window:
printf "\e[8;%d;%dt" $[LINES+5] $[COLUMNS+5]
.Xdefaults or .Xresources
Depending on your installation, you may have to store this on .Xresources instead of .Xdefaults.
FILES
Xrdb does not load any files on its own, but many desktop environments use xrdb to load ~/.Xresources files on session startup to initialize the resource database, as a generalized replacement for ~/.Xdefaults files.
Then after
sed -e '$axterm*allowWindowOps: true' -i.bak .Xresources
xrdb <.Xresources
Then...
Some bind samples
You could run this or add to your .bashrc:
# Some bind for 'Shift' + <direction> key and allowWindowOps resource
bind -x '"\e[1;2C"':'printf "\e[8;%d;%dt" $LINES $((COLUMNS+5))'
bind -x '"\e[1;2D"':'printf "\e[8;%d;%dt" $LINES $((COLUMNS-5))'
bind -x '"\e[1;2B"':'printf "\e[8;%d;%dt" $((LINES+3)) $COLUMNS'
bind -x '"\e[1;2A"':'printf "\e[8;%d;%dt" $((LINES-3)) $COLUMNS'
to be used with respectively: Shift+Right
, Shift+Left
, Shift+Down
or Shift+Up
Note: As this in bash bind, this will work in interactive command environment (aka not under vim nor less, read or any work in progress)
