I don't won't to use swap file (due to some bug in kernel or AMD driver).
I wan't to have some util running and monitoring free system memory and alerting me when it becomes less than some specified limit.
This will notify me that I need to close some applications (or browser tabs) to avoid system freeze due to some strange kswapd0 I/O activity (probably another bug).
Is there any appropriate software?
UPDATE:
I've redesigned script provided by Gary for my need and want to share it
#!/bin/bash
#Minimum available memory limit, MB THRESHOLD=400
#Check time interval, sec INTERVAL=30
while : do
free=$(free -m | awk '/^Mem:/{print $4}')
buffers=$(free -m | awk '/^Mem:/{print $6}')
cached=$(free -m | awk '/^Mem:/{print $7}')
available=$(free -m | awk '/^-\/+/{print $4}')
message="Free $free""MB"", buffers $buffers""MB"", cached $cached""MB"", available $available""MB"""
if [ $available -lt $THRESHOLD ]
    then
    notify-send "Memory is running out!" "$message"
fi
echo $message
sleep $INTERVAL
done
Carter
  • 322
You could try using free.
free -s n will update the output every n seconds. Wrap that in an if for whatever threshold you feel is "too much memory" being used, and display a message when it reaches that point.
EDIT: Here's the script I came up with. Rough, but it works.
#Checks for low memory.
#!/bin/bash
#cutoff_frac is basically how much used memory can be at in terms of how much
#total memory you have...2 is 1/2 of 100% or an alert when you're using 50% mem, etc.
cutoff_frac=2
total_mem=$(free|awk '/^Mem:/{print $2}')
let "threshold = $total_mem / $cutoff_frac"
while :
do
    free_mem=$(free|awk '/^Mem:/{print $4}')
    if [ $free_mem -lt $threshold ]
        then
        notify-send "Low memory!!"
    fi
    sleep 5
done
exit
Gary
  • 4,042
PHP version of the script:
The Free memory as shown in the system moniter is : Free= Total-(Used-buffered-cached)
What is the difference between the memory usage report in System Monitor and the one by free?
NOTE: To run this script as a cron job use:
* * * * *  env DISPLAY=:0.0 path/to/file 90
or
@restart  env DISPLAY=:0.0 path/to/file
uncomment the while loop to run it manually:
Code:
#!/usr/bin/php
<?php
$alert_percent=($argc>1)?(int)$argv[1]:90;
//$interval=($argc>2):(int)$argv[2]:25;
//while(true)
 exec("free",$free);
$free=implode(' ',$free);
preg_match_all("/(?<=\s)\d+/",$free,$match);
list($total_mem,$used_mem,$free_mem,$shared_mem,$buffered_mem,$cached_mem)=$match[0];
$used_mem-=($buffered_mem+$cached_mem);
$percent_used=(int)(($used_mem*100)/$total_mem);
if($percent_used>$alert_percent)
exec("notify-send 'Low Memory: $percent_used% used'");
//sleep($interval);
exit();
