The other day I was trying out different desktop environments, like Pantheon, Gnome, etc.
But when I was trying to install Pantheon/Elementary Shell, it came up with an error. I ignored it thinking it was nothing important (because it was just about the themes). And a few days before that, I was testing out different themes with the window manager and icons, one of the themes happened to be the Elementary Icon pack. Now whenever I try to install something it tells me to type in sudo apt-get -f install, and when I type it in, I get some errors. Here is the output:
$ sudo apt-get install cinnamon
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 cinnamon : Depends: gir1.2-muffin-3.0 but it is not going to be installed
        Depends: libmuffin0 (>= 1.1.2) but it is not going to be installed
        Depends: caribou but it is not going to be installed
        Depends: mesa-utils but it is not going to be installed
        Depends: gkbd-capplet but it is not going to be installed
        Recommends: nemo but it is not going to be installed
 elementary-artwork : Depends: elementary-theme but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
$ sudo apt-get -f install
 Correcting dependencies... Done
 The following extra packages will be installed:
  elementary-theme
    The following NEW packages will be installed:
  elementary-theme
    0 upgraded, 1 newly installed, 0 to remove and 41 not upgraded.
     2 not fully installed or removed.
     Need to get 0 B/57.4 kB of archives.
     After this operation, 415 kB of additional disk space will be used.
     Do you want to continue [Y/n]? y
 (Reading database ... 279974 files and directories currently installed.)
 Unpacking elementary-theme (from .../elementary-theme_3.2-0~r601+pkg289~quantal1_all.deb) ...
 dpkg: error processing /var/cache/apt/archives/elementary-theme_3.2-0~r601+pkg289~quantal1_all.deb (--unpack):
 trying to overwrite '/usr/share/themes/elementary/gtk-3.0/toolbar.css', which is  also in package elementary 3.1
E: Sub-process /usr/bin/dpkg returned an error code (1)"
In the notifications place (in unity the top bar, gnome the notification centre at the bottom of the screen) it has an error saying:
An error occurred. Please run Package Manager from the right-click menu or run apt-get in a terminal to see what is wrong. The Error message was: Error: BrokenCount > 0". This usually means that your installed packages must have unmet dependencies.
Zanna
  • 72,312
Scott
I found the fix to this, I just typed this command into the Terminal:
sudo dpkg -i --force-overwrite /var/cache/apt/archives/elementary-theme_3.2-0~r601+pkg289~quantal1_all.deb
Then I re-entered the previous command:
Then everything went back to normal and now everything is working just fine.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
