I have successfully install java for my ubuntu through terminal but in mobile project want to include Nokia SDK 2.0 but this Platform is not able to run without 32bit jre.
Error
The SDK could not locate a java runtime enviroment (JRE).You must install JRE6 to run this SDK.
Done
Then I have download 32 Bit jre form Oracle and install it into a folder but i understant where to move this folder OR set the path for 32 bit java. if anyone knows about it please help.
As if i check java from terminal
java -d32 -version
This Java instance does not support a 32-bit JVM. Please install the desired version.
