67
For security purposes my company wants me to not allow anyone to be able to log into our Ubuntu server as root remotely over SSH. We still want the root account to exist, we just do not want it to be able to be logged into remotely. How would I accomplish this?
Thank you very much in advance for your time.
Lekensteyn
  • 178,446
Rob S.
  • 1,651
I assume you meant logging in over SSH? Put the following line to /etc/ssh/sshd_config:
PermitRootLogin no
If you want to deny certain users from logging in, put this in the configuration file:
DenyUsers root
This takes the blacklisting approach. Whitelisting is generally preferable. If your company needs to allow the rob and admin users log in on the server, use the following configuration directive:
AllowUsers rob admin
After making configuration file changes, restart the ssh service using the command:
sudo service ssh restart
See also the manual page.
Kristian
  • 371
Lekensteyn
  • 178,446
16
Edit the file /etc/ssh/sshd_config, look for
PermitRootLogin
and set it to no.
Lekensteyn
  • 178,446
The default configuration is for the root account to be locked so you can not log in as root remotely. You don't have to do anything else, unless you also want to make sure that you can not log in as root remotely by using an RSA key. Of course, if you don't want to do that, then just don't set up a root key.
psusi
  • 38,031
