I just made my package by following tutorial. I recommend running qmake to create the Makefile, so that you don't run into problems while executing dpkg-buildpackage.
Steps
Assuming you have already setup the debian directory in the source code,
- Copy the source directory (where the
.pro file is) to your Home directory and rename it to yourProjectName_projectVersion.
- Open a terminal and execute
cd yourProjectName_projectVersion.
- Then, execute
dh_make -s -c gpl -e yourEmailAddress --createorig
- Finally, execute
dpkg-buildpackage. You may get something like error exit status 255, if so, check that the tar.xs file in you Home folder matches the file requested by dpkg-buildpackage (check the last lines of the output of dpkg-buildpackage to find out what file wants).
If you seek an easier and faster way, you can use Debreate (I did not test it, so I cannot assure you that it will work).
I hope this helps anyone who wants to distribute their Qt project.
