I'm trying to compile a program which uses Google's V8 library (which is 32 bit). Therefore any library I use within my program also has to be 32 bit. Where can I download the 32 bit version of libraries on Ubuntu 64 bit? More specifically, I'm looking for the libnotify 32 bit version.
This is the errors I am getting right now:
g++ -o shell -m32 shell.o -L../v8 -lv8 -lpthread `pkg-config --libs libnotify glib-2.0`
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../libnotify.so when searching for -lnotify
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../libnotify.a when searching for -lnotify
/usr/bin/ld: skipping incompatible /usr/lib/libnotify.so when searching for -lnotify
/usr/bin/ld: skipping incompatible /usr/lib/libnotify.a when searching for -lnotify
/usr/bin/ld: cannot find -lnotify
collect2: ld returned 1 exit status
Thanks!
You can install 32bit libraries on a 64bit machine by installing the ia32-libs package:
sudo apt-get install ia32-libs
Zanna
  • 72,312
Marco Ceppi
  • 48,827
